Thread: Getting rid of fuzzies
hi all. been machining for quite a while now mostly small parts which are easy to clean up, but now starting to do bigger pieces. I need a quick and easy way to get rid of fuzzies on my finished parts. I've seen a lot of people use small bristle brushes on dremel type machines in the usa but cannot seem to find the brushes over here in the uk. any links to these in the uk would be great and also any advice as how to remove fuzzies quickly and easily. cheers all
27-04-2013 #2
Hi John
I was down in St Austell last weekend!
The brushes they may be talking about i have read myself. I believe what they are talking about is the ones that look like little chimney sweep brushes? you would be better off changing your cutters in the first place though. Not experimented in this area myself and increasing the speed of the spindle.If the nagging gets really bad......Get a bigger shed:naughty:
28-04-2013 #3
Have a look on eBay search on dremel brush and you get nylon, brass, steel and stainless steel bristles. They don't last 5 minutes though.
Cheers, Rob
29-04-2013 #4
