Page 2 of 2 FirstFirst 12
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Spot on Good luck ...Clive
    You don't necessarily need to scale back the parts if you don't need to fit the part down the bore of the headstock.If not long lengths then you can fit them between centres(headstock and tailstock), use fixed and traveling steadies. You do have to keep in mind the swing of the lathe (centre height of chuck to the top of the bed). You could have a chuck with a 70mm bore if you have space to swing it but chances are you won't get a lathe with a headstock that can take 70mm. Not to fit in your workshop anyway.
    Ant,
    check your PM's
    John S -
  1. Here's an idea hacking a Kress 1050 FME
    By m.marino in forum Kress Milling Motors
    Last Post: 16-01-2013, 01:05 AM
  2. Why they don't want to accept my idea?
    By hoezap in forum Tool & Tooling Technology
    Last Post: 14-07-2012, 01:15 AM
  3. business idea?
    By homer93 in forum Marketplace Discussion
    Last Post: 01-06-2012, 12:56 PM
  4. Cheap Idea for a DRO
    By 1113562 in forum General Electronics
    Last Post: 27-02-2011, 04:20 PM
  5. BUILD LOG: Mel's Odd Idea
    By mel_earp in forum DIY Router Build Logs
    Last Post: 19-03-2010, 11:54 AM
