Thread: Eagle CAD problem
05-05-2013 #11
generally when working with Eagle I try to avoid specific parts for passive components unless there is a good reason. for resistors i generally use the library template for a generic 1/4w metal film which gives a suitable hole spacing. otherwise you can waste hours trying to match manufacturers parts to the library....
06-05-2013 #12
when i first started with eagle I used to search for hours trying to find the right library part....being of a lazy ilk - rather than face the time consuming effort that creating n Eagle part from scratch is - it occurred to me, there are only so many tranny/IC/passive packages in exsitence, so there's likely to be an eagle part for a totally different named part out there that fits the need.
That first part you mention....Recom R-788 0-1.0 ...from the datasheet, it's a regulator with 0.1" pitch leg spacing? So I googled the most common regulator on the planet a 780x regulator...and sure enough it's 0.1" pitch & has the same pin layout (pin 1 in, pin 2 ground, pin 3 output)....so you can be lazy too & just use a 7809 on your schem! (you might want to double check my lightning googling research on this ...can't be held responsible for your pcb not working blah blah!)Last edited by HankMcSpank; 06-05-2013 at 11:57 PM.
Powertran VFD problem
By phill05 in forum Spindles & Drive MotorsReplies: 7Last Post: 29-10-2013, 07:59 PM -
The Eagle has landed or rather "The ISEL has landed".
By GEOFFREY in forum Machine DiscussionReplies: 4Last Post: 04-09-2013, 01:33 PM -
Eagle Cadsoft help please
By Fivetide in forum General ElectronicsReplies: 6Last Post: 17-07-2013, 05:24 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
