    fivetide,
    I looked at your schematic to find the part number BD139 and then did a google on that number. This is an industry standard part number. HOWEVER, I just looked up the part number you referenced above and it is a 2N3904.
    Now looking at its pinout, and I can see the confusion!. It indeed does have the base in the center pin! You need to change the part no in your schematic to the correct one for the transistor that you have.
    Here is the url to the cut sheet that I have ref'd:
    http://www.fairchildsemi.com/ds/2N/2N3904.pdf
    HTH
    Art
    AKA Country Bubba
    (Older than Dirt)
    Thanks Bubba , thought i was going insane lol :)
    Ralph Waldo Emerson
    fivetide,
    Anytime my friend as I have been there done that and have the tee shirt to prove it!
    NEVER take anything for granted and then double check as you will usually be wrong.
    Don't ask:})
    Art
    AKA Country Bubba
    (Older than Dirt)
  4. The Following User Says Thank You to C_Bubba For This Useful Post:
  5. #4
    Quote Originally Posted by C_Bubba View Post
    fivetide,
    Don't ask:})
    Thanks Bubba, lol I love your name ! in fact I ended up watching one of my all-time favourite moves late last night, Forest Gump, because of the BubbaGump Shrimp thing !
    Anyway onwards and upwards .. I’m now (because I’m a noob to electronics) struggling with finding the Recom R-788 0-1.0 and R-&8b5 0-1.5 or something similar to put on the board .. any ideas what I can use from the eagle cad libraries ? there’s only really those two parts all the rest is wiring to them.
    Ralph Waldo Emerson
  6. #5
    I am not familiar with either one of those devices so can't really help you. I did find a while back on youtube a tutorial on how to build up your own devices for eagle. So far, my success at doing this is limited (I am new to Eagle). There is also a yahoo group that deals with Eagle and you might check into that and see if anybody has done what you need.
    As for the moniker, many years ago several of us that worked together had a project manager who called everybody bubba. Well, I lived in the country and another lived in the city so that is how we got distinguished when he called for bubba! LOL
    Art
    AKA Country Bubba
    (Older than Dirt)
  7. generally when working with Eagle I try to avoid specific parts for passive components unless there is a good reason. for resistors i generally use the library template for a generic 1/4w metal film which gives a suitable hole spacing. otherwise you can waste hours trying to match manufacturers parts to the library....
  8. #7
    when i first started with eagle I used to search for hours trying to find the right library part....being of a lazy ilk - rather than face the time consuming effort that creating n Eagle part from scratch is - it occurred to me, there are only so many tranny/IC/passive packages in exsitence, so there's likely to be an eagle part for a totally different named part out there that fits the need.
    That first part you mention....Recom R-788 0-1.0 ...from the datasheet, it's a regulator with 0.1" pitch leg spacing? So I googled the most common regulator on the planet a 780x regulator...and sure enough it's 0.1" pitch & has the same pin layout (pin 1 in, pin 2 ground, pin 3 output)....so you can be lazy too & just use a 7809 on your schem! (you might want to double check my lightning googling research on this ...can't be held responsible for your pcb not working blah blah!)
  1. Powertran VFD problem
    By phill05 in forum Spindles & Drive Motors
    Last Post: 29-10-2013, 07:59 PM
  2. The Eagle has landed or rather "The ISEL has landed".
    By GEOFFREY in forum Machine Discussion
    Last Post: 04-09-2013, 01:33 PM
  3. Eagle Cadsoft help please
    By Fivetide in forum General Electronics
    Last Post: 17-07-2013, 05:24 PM
  4. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
