Thread: Cable Size ?
Hi everyone.
I have nearly finished wiring my first CNC control cabinet, I have used 7/0.2 cable for the 5 volt supply, but when I came to wiring up the Motors (I have 3 Nema 23's) I had a thought, the voltage is higher (36 volt) so what size cable do i need for the motors to the Driver boards? and do i need to shield them, if yes i can i do this simply?
Regards
Ray
09-05-2013 #2
The voltage doesn't matter. I'ts the current that determines the size of the wires. 7/0.2 is rated at 1.4 Amps so is a bit light for your motors. It does depend on the motor rating which could be up to about 3 A depending on the exact model. I would go for at least 16/0.2.
Screening should not be needed within the cabinet provided you keep the input signal wires away from the motor wires.
Russell.
The Following User Says Thank You to russell For This Useful Post:
VFD to motor cable wire size (Gauge)
By artman12us in forum Spindles & Drive MotorsReplies: 2Last Post: 24-04-2014, 07:11 PM -
CY cable terminals
By kingcreaky in forum Marketplace DiscussionReplies: 15Last Post: 26-03-2014, 08:24 AM -
motor and spindle cable size?
By paulus.v in forum General ElectronicsReplies: 4Last Post: 04-02-2014, 10:18 PM -
cable prices
By deannos in forum Marketplace DiscussionReplies: 15Last Post: 10-12-2012, 10:25 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
