  1. #14
    Quote Originally Posted by Fivetide View Post
    Thanks MC very much appreciated, I’d like to think of this project as evolving so adding things to make it better is exactly right
    I have some 220 uF 25v Low ESR 8mm dia x 15 mm high 3.5 mm LS ( UPW1E221MPD) from a project also some Panasonic small-form but not sure what stats
    They would be fine - you don't need anything special like low ESR, but no problem using them. Still need ceramic capacitors on the input.
    What voltage are you supplying to the 5V regulators and at what current?
  1. routing aluminium help :)
    By don_jarr in forum Metalwork Discussion
    Last Post: 27-11-2012, 09:05 PM
  2. PCB Isolation Routing
    By Mad Professor in forum General Discussion
    Last Post: 16-03-2011, 09:46 PM
  3. PCB Isolation Routing
    By CHudson in forum Milling Machines, Builds & Conversions
    Last Post: 10-10-2010, 08:34 PM
  4. BUILD LOG: routing 3d?
    By proddy in forum DIY Router Build Logs
    Last Post: 03-08-2009, 11:20 PM
