    OK yes I can see the advantage of this, especially on larger boards. for me it wouldn't be worth it, the only boards I do are 100x 100 max.
    The boards I make are typically even smaller than that - 70mm x 40mm ....I mill relatively small traces for SMD (SOT23-5 is as small as I go) & being able to probe is essentaial with a V cutter to get decent track width result.
    Z Probing allows me to essentially disregard how flat the copper board is (& the inevitable clamping 'bow')...but more importantly I can disregrad how uneven the machine bed &/or spoiler material may be.
    I only have art cam so I'm not sure how to import gerber files into it, I've done a google and its not much help, basically I have been creating a pdf bringing in the monochrome to artcam and converting them to vectors.
    Ralph Waldo Emerson
    gerber files are created by your pcb design software.....what are you using to design the pcb? (I'm not familiar with art cam...cambam has a free trial period & can import gerbers)
    Quote Originally Posted by HankMcSpank View Post
    I'm using eagle for PCB , ah ok I'll give cambam a trial see if it can do the PCB's thanks Hank
    Ralph Waldo Emerson
    If your using Eagle, you can use pcbgcode.ulp to create the necessary drill files as well as the router isolation files.
    Art
    AKA Country Bubba
    (Older than Dirt)
  1. What tooling to drill lots of 10mm holes 45mm deep?
    By AlanMJackson in forum Tool & Tooling Technology
    Last Post: 13-01-2014, 08:53 PM
  2. Drill 4 x 28mm holes through 44mm thick aluminium
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 30-09-2012, 09:17 AM
  3. Now if only someone invented a drill that drilled square holes.....
    Last Post: 20-10-2011, 10:07 PM
  4. Replies: 3
    Last Post: 27-09-2011, 11:57 PM
