Thread: oxy propane cnc preheat problem
Stick a P04 10.0 into the code before the Z move
John S -
12-05-2013 #2
he i have finally sorted the problem. mach 3 was reading the pause code as ms instead of seconds. but when the torch goes to preheat it is moving up to the peirce height and not the cut height. is there any way to fix this in sheetcam? i am after cut and pre-heat at 3mm and pierce at 25mm
thanks
ROB
Powertran VFD problem
By phill05 in forum Spindles & Drive MotorsReplies: 7Last Post: 29-10-2013, 07:59 PM -
Another screw problem
By Swarfing in forum Marketplace DiscussionReplies: 5Last Post: 27-03-2013, 09:24 PM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM
