    So finally I've got round to starting this build log (to help motivate me to finish the build!)
    The specs -
    Cutting area of 3050mm x 1525mm x 150mm
    Aluminium/Steel Construction
    Hiwin Linear Guides (25mm & 15mm)
    Rack & Pinion all 3 axis
    Closed loop steppers (through belt reduction 3:1)
    1.2kw HF Spindle
    Option for tangential cutting knife
    USBCNC software CPU5B
    Full Vacuum Bed made from aluminium box section.
    So now you know where I'm going, this is what you all want, PICTURES! Click image for larger version.
ID:	8938Click image for larger version.
ID:	8939Click image for larger version.
ID:	8940Click image for larger version.
ID:	8941Click image for larger version.
ID:	8942Click image for larger version.
ID:	8943Click image for larger version.
ID:	8944Click image for larger version.
ID:	8945Click image for larger version.
ID:	8946Click image for larger version.
ID:	8947Click image for larger version.
ID:	8948Click image for larger version.
ID:	8949Click image for larger version.
ID:	8950Click image for larger version.
ID:	8951Click image for larger version.
ID:	8952Click image for larger version.
ID:	8953Click image for larger version.
ID:	8954Click image for larger version.
    WOW!! This is a monster! Looking really good mate, doesn't look like you are too far off. I have seen your other machine before on here I think? I'm getting there slowly with my router build, but this is inspiring me to take it up a gear and get it finished!
    That looks really professional - well done. G.
    PSG's Avatar
    Lives in Ashford, United Kingdom. Last Activity: 19-02-2015 Has been a member for 9-10 years. Has a total post count of 13.
    hi, this is my first post, and your build looks absolutely amazing. is this for timber panels? only judging by the size, this looks to be the case. I am looking to build a machine for a 2400 x 1220 sheet capacity, and have looked through a lot of the builds and cant find one like this that caters for that. You built another previously, is that a smaller one? i like this style that runs on alu extrusions rather than rails, if i am correct in saying. Is this what is called a gantry?
    I am not asking for a one on one tuition here, but how do i learn to build a machine like this for the 8x4 size, and where can i get the info? I am a complete beginner, but there is no beginner threads on here that show step by step, that i can find anyway. I have read loads of build threads, but i have no knowledge of the terminoligy used etc.
    Any help welcome. will you be documenting this build further?
  1. Rack & Pinion Gearbox/Gearing
    By andrewbond in forum Rack & Pinion Systems
    Last Post: 12-09-2015, 09:10 AM
  2. z axis rack and pinion advice
    By marbles in forum Gantry/Router Machines & Building
    Last Post: 09-01-2013, 11:41 PM
  3. Rack and Pinion MOD 1 & MOD 2 diffrence
    By D-man in forum Rack & Pinion Systems
    Last Post: 07-11-2012, 03:29 PM
  4. Rack and Pinion
    By pmcb1011 in forum Rack & Pinion Systems
    Last Post: 31-05-2011, 11:55 AM
  5. Headsup for the Hemsworthlad! Rack and Pinion
    By Smiler in forum Rack & Pinion Systems
    Last Post: 14-06-2009, 11:36 PM
