    Hey guys, I have uploaded a quick video showing the issue.
    The issue I am having is when I try and snap near a circle, there is a gap between the circle and the line I am drawing.
    What really odd is when it is 'snapping' the snap isn't actually on the circle but hovers away from it!
    When I do the same thing next to a square or a straight line there is no problem.
    I tried REGEN and REGEN all this did no help unfortunatley.
    I hope the small video is clear enough to explain the issue and I really hope someone can help me.
    Please accept my appologies for the poor quality of the video
    Autodesk 2013, Help with Osnap to a circle. - YouTube
    Have you checked the settings in osnap I only have autocad 2004 and the tabs are along the bottom you have to right click on them to get to settings also you might have grid snap on hope this helps ..Clive
    Have a look at this, I posted here too - May help to explain a little better.
    Major issue with snapping to circles. - Autodesk Discussion Groups
    I'me sorry I could not open that file in my copy of autocad but perhaps could with a dxf file. ...Clive
    hei'ya craigrobbo, l'm a bit late to the party, but have a look in the dwg attach. - kelef
    Attached Files Attached Files
    Gregbeeker's Avatar
    Location unknown. Gregbeeker Last Activity: Has a total post count of n/a. Referred 6518 members to the community.
    Your osnape is working correctly, what I believe is happing is that you are seeing a gap in the segments of the circle. The circle is displayed in straight line segments.
    I hope this helps.
    Greg
    Gregbeeker's Avatar
    Your osnap maybe ok, the circle is drawn in segments, copy the circle on top of itself and rotate it 30 degrees , then zoom in.
    Greg
    hi, new to this forum, just watched the video and it looks like you should regen drawing in the edit menu. When zoomed in that far and it will appear round again. As others have said it is segmenting into straight lines and your snap is actually in the right place
    I think this guy might have worked it out by now as the post is about 7 months old. ..Clive
  1. 3d AutoCad CNC machine parts.
    By jcb121 in forum Open Source Designs & Plans
    Last Post: 09-10-2014, 10:18 PM
  2. Replies: 2
    Last Post: 23-11-2013, 02:05 PM
  3. ArtCAM 2013 Delcam demos/webinars
    By Becky f in forum Manufacturer News
    Last Post: 29-10-2013, 05:02 PM
  4. AutoCad 2007
    By D-man in forum CAD & CAM Software
    Last Post: 05-08-2012, 05:51 PM
  5. Getting dizzy cutting circles!
    By fasteddy in forum Programmers Corner
    Last Post: 16-05-2010, 07:46 AM
