    ballscrews all the way...worth 20 times the cost of the leadscrews.
    What he said..
    You can easily get rid of backlash in lead screws by tensioning (or compressing) two nuts together but the resultant friction is often more of a problem than the backlash. My little mill has has this type of anti-backlash and I can get pretty much zero backlash but the friction is so high it is difficult to turn the hand wheel and impossible to get smooth motion. as already pointed out this will also result in the screw wearing out quickly.
    The halfway house is to use brass nuts and a hydraulic tensioning system to self adjust for the wear and then replace the nuts as when they totally wear out. but by the time you set that up it is probably easier and cheaper to get a ball screw.
    Don't be tempted to use delrin, been there done that and it has no place in milling machine. I've learnt from my mistakes and I'm getting ball screws for the next one.
  2. The Following User Says Thank You to Ross77 For This Useful Post:
  3. #2
    Done a few WM16's and one thing to bear in mind is that some convert easily and some don't.
    The stumbling block is the bed in the middle, the casting when being cast, sags and make the gap tighter in the middle.
    No problem with the top, that's machined so no sag. From the ones I have done it's 50/50 if a ballnut clears.
    So worst scenerio is to get someone with a big mill to take a lick out or angle grind a clearance grrove.
    WM14 are usually OK, I haven't come across a bad one but WM 18's 'always' need machining
    John S -
  4. The Following User Says Thank You to John S For This Useful Post:
  5. #3
    Many Thanks, Any thoughts on the couplings?
    Ray
  6. #4
    Oldhams, they are the only non backlash coupling that works CORRECTLY in two planes.
    All the others are fück ups.
    John S -
  7. The Following User Says Thank You to John S For This Useful Post:
  8. #5
    Hi John
    I agree, i have used Oldham couplings for many years, i just thought things may have moved on a little, they seem so expensive these days.
    Regards
    Ray
  9. #6
    Unless I'm out of touch with other couplings, not that I'd use them, I thought they were about the same price.
    I get mine from ARC, used to buy off RS but they have cut their range right down.
    John S -
  10. Not sure if you have looked at buying your ballscrews from China? There is a massive cost difference between China and the UK. Check out Linearmotionbearings2008 on ebay.
  11. The Following User Says Thank You to JoeHarris For This Useful Post:
  1. Looking into a ballscrew, not sure if I should buy. Help
    By oldmam4m80s in forum Lead Screws, Nuts & Supports
    Last Post: 28-07-2017, 10:15 PM
  2. WANTED: Ballscrew and nut
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 04:25 AM
  3. Ballscrew Woes, help please!
    By jonbabbz in forum Lead Screws, Nuts & Supports
    Last Post: 21-04-2012, 12:16 AM
  4. Where to get C3 & C5 Ballscrew
    By AdCNC in forum General Discussion
    Last Post: 10-08-2011, 06:56 PM
  5. FOR SALE: Looking for a ballscrew (eBay)?
    By Smiler in forum Items For Sale
    Last Post: 16-05-2009, 03:22 PM
