Thread: Ballscrew or leave alone?
You can get 12mm (RM1204) ballscrews from linearmotionbearings2008 on eBay. The steel the ballnuts is made from is just about soft enough to mill, so if you need to make them a bit smaller that's a cheap option. It's probably easier to grind it and glean the nut thoroughly afterwards. Clearly the stiffness and critical speed of the screw are both reduced if it's smaller, however in this instance neither is significant since it's a small machine.
The Following User Says Thank You to Jonathan For This Useful Post:
25-05-2013 #2
Have you got any space between the base and end plate on the bottom axis (Y- I think on a mill)? I'm just looking to put ballscrews on my mill and want the biggest diameter possible as it is only supported on one end. The channel between the ways is too small for 20mm dia. ball nut but I have space to move it forward and mount the nut flange on the face of the base.
Any way just a thought.
The Following User Says Thank You to Ross77 For This Useful Post:
Looking into a ballscrew, not sure if I should buy. Help
By oldmam4m80s in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 28-07-2017, 10:15 PM -
WANTED: Ballscrew and nut
By D-man in forum Items WantedReplies: 8Last Post: 30-08-2013, 04:25 AM -
Ballscrew Woes, help please!
By jonbabbz in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 21-04-2012, 12:16 AM -
Where to get C3 & C5 Ballscrew
By AdCNC in forum General DiscussionReplies: 10Last Post: 10-08-2011, 06:56 PM -
FOR SALE: Looking for a ballscrew (eBay)?
By Smiler in forum Items For SaleReplies: 13Last Post: 16-05-2009, 03:22 PM
