Page 1 of 3 123 LastLast
    Question on PCB and routing , well more .. will it work I guess ? Anyway I have hammered the tutorials and finally got to where I think I can start to mill the board. Only thing is is a question on power voltage etc. as you can see I have highlighted my concern in a red box , this is two molex 2 male pin plugs , I want to draw power from both as they go to different parts of the hardware .. will this work ? Will this affect the voltage ?
    and blew a close up :)
    any help as normal appreciated :) only had four beers so far .. record lol BTW the board is tiny only only 60mm x 40mm .
    Ralph Waldo Emerson
    As long as your within the limit of what the regulator can supply AND the traces are wide enough for the current desired, it should work.
    Art
    AKA Country Bubba
    (Older than Dirt)
    Lives in East Lothian, United Kingdom. Last Activity: 3 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Depending on current, it may mean a slightly higher voltage drop at X7, however provided that whatever you're powering from the connectors aren't going to be affected by noise/voltage spikes from each other, and you're not going to overload the tracks, it'll be fine.
    Quote Originally Posted by C_Bubba View Post
    I've made the traces as wide as possible, I think it should be able to handle the current , suppose I wont know until I try it Bubba lol , again thanks for the reply mate :)
    Ralph Waldo Emerson
    Hi MC , nah the last on the rail powers two 5v servos the first powers a raspberry pi , i'll have to rethink if it drains or spikes to much, but they are 7 quid a pop I would expect then to have some umthh ! lol
    Beer 5 ..now poured !
    Ralph Waldo Emerson
  6. Quote Originally Posted by Fivetide View Post
    Use this: The PCB Track Width Calculator to calculate track width...
    Incidentally, 3-pin regulators should have 10 - 100nF ceramic capacitors on input and output else things can get noisy. See their datasheets.
  7. The Following User Says Thank You to irving2008 For This Useful Post:
  8. #7
    Hi Irving hope your feeling ok , they are used for pure power no signal its just a drop down box.
    Ralph Waldo Emerson
  9. Quote Originally Posted by Fivetide View Post
    read the datasheets... HF noise on power lines can cause all sorts of issues.. trust me, been designing electronics for 40 years!
  10. #9
    So you think I should add 10k's at the voltage out ? I'm going off the guys schematic , he didnt include them only on the data line.
    PI Tank power
    Ralph Waldo Emerson
  11. #10
    I normally include an electrolytic cap on the output of linear regulators, then add a ceramic near the input of anything that may be affected by noise.
    Although things may work without caps on the linear regs, it's not good practise. Lots of linear regulators specify minimum capacitence on the output lines in their datasheets.
  1. routing aluminium help :)
    By don_jarr in forum Metalwork Discussion
    Last Post: 27-11-2012, 09:05 PM
  2. PCB Isolation Routing
    By Mad Professor in forum General Discussion
    Last Post: 16-03-2011, 09:46 PM
  3. PCB Isolation Routing
    By CHudson in forum Milling Machines, Builds & Conversions
    Last Post: 10-10-2010, 08:34 PM
  4. BUILD LOG: routing 3d?
    By proddy in forum DIY Router Build Logs
    Last Post: 03-08-2009, 11:20 PM
