Hi there birchy, I am planing to do the same thing to my WM16 (fed up with changing brushes) but am thinking about keeping the 2 speed gearbox but replacing them with steel gears to give me a degree of backgear. The primary drive will be by toothed belt I think. Have you come across ant major problems with your conversion?
Regards Mark P.
06-01-2017 #2
If you have money to burn you can go the AC servo route and get 1.65Kw in a 85mm square flange motor and you will have more power than you will need on that small machine.
http://www.kollmorgen.com/en-gb/prod...-servo-motors/
Graham
FOR SALE: (G0704 SPG 2217 Champion 20V Mill Warco WM 16) DC motor
By fragger6662000 in forum Items For SaleReplies: 0Last Post: 09-10-2011, 05:59 PM -
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Warco VMC Turret Mill - CNC Conversion
By antsals in forum Conversion Build LogsReplies: 33Last Post: 07-03-2011, 12:25 AM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM
