A friend showed me some FB-2 bits he knew I would want and casually mentioned that he needed a Unimat milling head modifying for CNC use on his Emco CNC Lathe (kind of like a CNC Micro-Mentor).
This is what I came up with,
the column is 01 Tool Steel turned to fit the head bracket, the two sections machined away are to allow quadrant shaped gib strips to drop in, the ally plates top and bottom ensure the gib strips move exactly with the head.You think that's too expensive? You're not a Model Engineer are you? :D
CONVERSION: EMCO Compact 5 CNC Conversion
By sid8ball in forum Conversion Build LogsReplies: 1Last Post: 10-10-2019, 11:51 AM -
CONVERSION: Emco Mentor Mill conversion
By Ross77 in forum Conversion Build LogsReplies: 63Last Post: 13-01-2016, 06:40 PM -
SOLD: Emco Unimat 3
By Boyan Silyavski in forum Items For SaleReplies: 2Last Post: 21-05-2014, 05:33 PM -
Emco conversion help needed
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 29-03-2014, 10:33 PM -
Emco Compact 5 Conversion
By Pete92 in forum Emco LathesReplies: 7Last Post: 01-10-2013, 11:31 PM
