    can I simply have my power supply in a seperate box. - IF you like, like a laptop power supply
    with the three + and - feeds and an earth going to another box with the controllers and bob in?
    can I use abs plastic boxes
    reason why is, I would like the 3 motor feed wirescoming straight into the box and connected straight to the controllers, rather than having connectors, as I have connectors on the motors. Also I can then put the 240 out of the way and have the 36 mounted to the machine.
    also I can use smaller boxes, with the giblets orientated better.
    also while I am on, after I connect the controllers to the parralel port bob, do I then leave the cable inside and mount it to a usb step driving affair, at this moment should I be buying a usb complete break out board, rather than parralell stuff
    can I then simply fit a wireless doofer to the usb port and send stuff to it wire-less.
    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Quote Originally Posted by nobby View Post
    Yes. No reason anything has to be in the same box, other than it's usually cheaper.
    However you need to feed all the stepper drivers from a common start point, not by looping the power from one drive to the next.
    Depends. Anything that may be suceptable to noise i.e. low voltage control signals, is ideally better kept in some kind of sheilded enclosure, however given lots of people combine power supplies, motor drives, and all the control electronics in the same enclosure, it's not that major an issue provided you use sheilded wiring and good grounding practice.
    Parallel v. USB depends entirely on what controller/software you plan on using, and is a whole seperate debate.
    NO!
    Machine control requires very accurate timing and reliable communication, which wireless is not reliably capable of.
  1. Power Supply Suggestions please..
    Last Post: 30-01-2013, 06:37 PM
  2. PS806-5 Power Supply
    By Washout in forum General Electronics
    Last Post: 11-11-2012, 03:07 PM
  3. Replies: 0
  4. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
