Thread: Mach3 & V-Carve Problem
How mad is that, i didnt even check that because its a fresh install on a new pc and i know i selected MM, then in manual mode it worked fine, however, not with a program loaded with a g-code instruction stating metric!!. well it looks like you were correct, because when i checked it was set to Metric.... so go figure???
Rick
thanks Jonathan... its still odd thoughAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
symmetrical hart shape in vectric v carve pro
By cockneyrebel in forum VectricReplies: 15Last Post: 24-02-2014, 02:55 PM -
diyCAM: Carve Released – Half off ($25) for first 50 customers!
By Chemeleon in forum Manufacturer NewsReplies: 0Last Post: 19-08-2013, 12:46 AM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM -
Z Problem
By airwolf in forum Machine DiscussionReplies: 2Last Post: 10-11-2009, 08:08 AM -
Machine problem with softlimits mach3 & Estop
By Steve-m in forum Artsoft Mach (3 & 4)Replies: 9Last Post: 12-01-2009, 05:38 PM
