Thread: Digitizing probes practicality
I am looking at items 15093104978 and 29089129543
How much do you all use digitizing probes for copying objects ? I think this is a nice idea, but not sure how much it would actually get used, and would like to know if it is as simple to create gcode and replicate objects as the youtube videos make out ?. Can it all be done with the wizard in Mach3 ? . For example, if I were to digitize an object that needed multiple tool changes, how would I edit the gcode to instruct mach3 when to stop etc ? The further I look at " if's and but's" the more unapealing the digitizer probes become. Are these just for copying profiles ? rather than anything else ?Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
02-06-2013 #2
Well i did ask myself the same questions, until i bought one... Today i was machining a double sided part, luckily it had a 32mm hole right through it, so when it came to flipping the part over and positioning it correctly, the hardest part was programming the scripts in Mach, the rest went flawlessly in fact it was easy, I was gobsmacked... i will let you know about copying and making parts later on in the month...HE HE HE
I dont know how i managed without it..... well the honest answer is that it was painfull to do a double sided part..
Rick
The probe i purchased wasnt the cheapest, but im happy i got it
Touch Probe cMm Digitizing Renishaw Haas Fadal CNC Mill Lathe Router ENGRAVER | eBayLast edited by Ricardoco; 02-06-2013 at 09:23 PM.
04-06-2013 #3
Yes, please let me know as soon as you have tried replicating.
Mach3 digitizing wizard not saving file
By dudz in forum Probing, Digitizing & ScaningReplies: 0Last Post: 08-09-2013, 09:48 PM -
Digitizing probe / Point cloud to mesh
By dudz in forum Probing, Digitizing & ScaningReplies: 4Last Post: 07-09-2013, 10:03 PM -
Spindle probes for centering
By maritimesbob in forum Probing, Digitizing & ScaningReplies: 4Last Post: 02-09-2012, 11:22 PM -
Probing / Digitizing - What the best way to do this job?
By Mad Professor in forum Probing, Digitizing & ScaningReplies: 2Last Post: 08-05-2011, 12:32 PM -
Digitizing
By Mad Professor in forum Probing, Digitizing & ScaningReplies: 2Last Post: 06-01-2011, 06:52 PM
