Thread: My acquisition.
Page 2 of 2 FirstFirst 12
    G the video is saying it is private
    With the machine against one wall i would keep it, 2' is plenty of room honest
    Quote Originally Posted by Swarfing View Post
    Fixed video.... re machine...I doubt il get rid of it anyway!... 2' wont leave me much space for all my other previous toys ; D
    I reckon with the machine you could you could build some timber panels for an extension to the garage ;-)
    Quote Originally Posted by kingcreaky View Post
    and as the highlight of all your evenings... here is the z moving
    Thanks..... Lots better than much of free to view TV these days.
    It's looking more and more like you picked up a great bargain..... Well done!
    dunno. but if a mod is reading this please delete the duplicate...
    All done.
    .Me
    8 wires means the motor is most likely similar in wiring to the ones on your first machine, that is 4 windings and two per phase. You should be able to use the same method to identify the 4 pairs of wires for the 4 windings, then you just need to know which two are which phase so you can put them in parallel (or less likely series). I'm pretty sure you can safely do that by connecting to the driver and just trying the four possible combinations - one will just work and the motor will only go a couple of steps forwards and backwards with the others.
    Is there definitely no part number on the motors?
    Right. about killed myself tonight lifting these bad-boys onto the trailer. Tomorrow I intend to drive over to my friends unit where there is the magic "three-phase" I can temporarily wire these in, to proove they work. Then Il put them on the bay. As ultimately im going to need single phase ones in order to use the vacume bed in my workshop
    However, can anybody shed any light on what im looking for... how do I tell they work? I assume they are like big vaccuume cleaners... except I wont put my hand near the inlet as I guess it will suck it off? (my hand)
    I assume the following
    I guess the square blue tanks need to perhaps be filled with water? I say this as their is what looks like a sight glass on the side (labelled E) ...
    if anybody could tell me what im expecting to see from each of the labelled ports... and perhaps confirmation of whether im meant to be filling the blue square units with anything id really appreciate your feedback ;)
ID:	9211Click image for larger version.
ID:	9212Click image for larger version.
ID:	9213Click image for larger version.
ID:	9214Click image for larger version.
ID:	9215Click image for larger version.
    Research some more, a vfd and you could put them to use if you ask me? Seem rather large but who knows?
    right, tired of these things being in the way, going to bang them on ebay
    surely they would have originally had a starter of some description? would it be this badboy? or would this be the controller for the spindle that was on it?
    What do I describe them as? 'Vacuum Pumps' , 'Vacuum Motors' if you where searching for them what would you search for?
    Matt
