Thread: My acquisition.
  1. #31
    Quote Originally Posted by kingcreaky View Post
    and as the highlight of all your evenings... here is the z moving
    Thanks..... Lots better than much of free to view TV these days.
    It's looking more and more like you picked up a great bargain..... Well done!
  2. #32
    8 wires means the motor is most likely similar in wiring to the ones on your first machine, that is 4 windings and two per phase. You should be able to use the same method to identify the 4 pairs of wires for the 4 windings, then you just need to know which two are which phase so you can put them in parallel (or less likely series). I'm pretty sure you can safely do that by connecting to the driver and just trying the four possible combinations - one will just work and the motor will only go a couple of steps forwards and backwards with the others.
    Is there definitely no part number on the motors?
  3. #33
    Right. about killed myself tonight lifting these bad-boys onto the trailer. Tomorrow I intend to drive over to my friends unit where there is the magic "three-phase" I can temporarily wire these in, to proove they work. Then Il put them on the bay. As ultimately im going to need single phase ones in order to use the vacume bed in my workshop
    However, can anybody shed any light on what im looking for... how do I tell they work? I assume they are like big vaccuume cleaners... except I wont put my hand near the inlet as I guess it will suck it off? (my hand)
    I assume the following
    I guess the square blue tanks need to perhaps be filled with water? I say this as their is what looks like a sight glass on the side (labelled E) ...
    if anybody could tell me what im expecting to see from each of the labelled ports... and perhaps confirmation of whether im meant to be filling the blue square units with anything id really appreciate your feedback ;)
ID:	9211Click image for larger version.
ID:	9212Click image for larger version.
ID:	9213Click image for larger version.
ID:	9214Click image for larger version.
ID:	9215Click image for larger version.
  4. #34
    Research some more, a vfd and you could put them to use if you ask me? Seem rather large but who knows?
  5. #35
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    5.5Kw and 380 delta means you'd need one hell of a single phase supply to power them, along with a meaty step-up transformer and inverter.
    If it wasn't for the plastic taps, I would of said the tanks were for oil as most vacuum pumps are oil lubricated. Is there any kind of gunk/residue in the tanks?
    Anyway, here's my guess-
    A - taps, possibly been bodged for some reason, or might of been some kind of cooler loop connection.
    B - vent - pump would pump air/oil into the tank, and it's got to get out somewhere
    C - Vacuum connection point - pump sucks air in here, and I'd hazard a guess the big housing contains a filter
    D - Oil scavenge feed into pump - the pump contiually pulls in oil along with air for lubrication
    E - Level tube
  6. The Following User Says Thank You to m_c For This Useful Post:
  7. #36
    After doing a little bit of research, I think these vacuum pumps might be whats called a liquid ring type vacuum pump, where in actual fact you would fill part of the system with water, though I'm not certain where... These types of pumps seem to be common with the chinese imported machines, maybe there is some documentation from a supplier of a similar machine?
  8. The Following User Says Thank You to drumsticksplinter For This Useful Post:
  9. #37
    This diagram might help:
Name:	liquid ring pump.png
  10. The Following User Says Thank You to drumsticksplinter For This Useful Post:
  11. #38
    right, tired of these things being in the way, going to bang them on ebay
    surely they would have originally had a starter of some description? would it be this badboy? or would this be the controller for the spindle that was on it?
    Attachment 9020
    What do I describe them as? 'Vacuum Pumps' , 'Vacuum Motors' if you where searching for them what would you search for?
    Matt
  12. #39
    finally found time to get this machine working
    nothing worse than hearing your own voice!
  13. The Following 2 Users Say Thank You to kingcreaky For This Useful Post:
