Jonathan
Thanks for doing that. not sure i got the answer i was hoping for :(
Basically I was hoping that applying dc to one coil of a stepper it would act as a brake. the lathe clearly has much more grunt so no braking effect was seen (frequency is near identical) and the output voltage from the second winding is essentially the same so isnt a measure of braking force.
i wonder if turning it by hand would empirically show the braking effect and maybe measure the effect using pulley and falling weight approach
11-06-2013 #2
The stepper motor is definitely applying a torque opposing the lathe and if I just hold the motor it feels like that torque is a function of the phase current - presumably they're proportional. The torque ripple is high though since we're operating it as a single phase motor.
I think measuring the torque using the method I suggested earlier would be easier?
11-06-2013 #3
11-06-2013 #4
If we're just using it as a load, since it doesn't look like we can get useful information from the other phase, then yes I tend to agree. Also you wouldn't get rated power with just one phase energized.
Yep, could even use dropping a weight to calibrate the other system.
11-06-2013 #5
It's great seeing you two "talking dirty" with one another again
11-06-2013 #6
