Thread: Front face DIY decals advice ..
Low tack is possibly not the best way to go David, it would be quite easy to lift the edge of a low tack tape while machining which would then allow the paint to bleed under the tape when applied.
What you want is a removable vinyl, one that comes off clean & doesn't leave lots of glue residue behind. I would try & get some samples of Paint mask films & short term removable vinyl films. If your not using a liquid coolant then even a medium tack application tape might do, that would be the cheapest option if it worked.
11-06-2013 #2
Thanks Martin , any recomendations .. that I might be able to buy say from eBay or should I go to a bodyshop/ sprayshop ?
Ralph Waldo Emerson
11-06-2013 #3
Sent you a PM David
12-06-2013 #4
From my bookmarks file: Make your own custom DRY TRANSFERS in less than 10 minutes with "DecalPRO"
12-06-2013 #5
Or from the UK here:
DecalPRO FX new for applying decals to any surface with no carrier film.
12-06-2013 #6
Thanks Martin great information as normal.
Thanks for the links guys, Martin got me thinking maybe I'm over complicating this, I have contacted a custom decal maker on eBay for a prices , I can get loads of the front faces on a single A4 sheet so might be cost effective . also make some nice customisation for the tops ;)
Ralph Waldo Emerson
13-06-2013 #7
Depends what sort of look you want David, a sticker is always going to look like a sticker, could dome it so it's a bit more up market but it will still look like a sticker. I think engraving & then infilling with paint would give a far better finish, would last better but at an increased cost in time if nothing else.
Oh & what's this " I've contacted a custom decal maker on ebay" all about ???? Am I not good enough for you lol
Looking for some CAM advice
By m_c in forum DolphinReplies: 4Last Post: 15-12-2013, 10:17 PM -
RFQ: Z axis front plate
By Shinobiwan in forum Projects, Jobs & RequestsReplies: 7Last Post: 11-11-2012, 12:41 AM -
Milling profile and flat face
By hoezap in forum Tool & Tooling TechnologyReplies: 2Last Post: 23-08-2012, 11:35 PM
