Thread: Various nema 23's
22-01-2013 #1
Hey guys what's the biggest difference between all the nema 23 style stepper motors? I'm aware that specific to my needs I should be looking for 439oz 3.1nm steppers but I don't know why.
Whilst looking for the wantai drivers I notice that company sells 425oz steppers but not the 439oz ones.. How big of a difference is that?? If need be I'll come back later and give links
22-01-2013 #2
No difference at all, in fact it's probably hype they can't prove
John S -
22-01-2013 #3
you mean the 425 and 439oz are likely to be the same? no one has actually said they are/are not yet i'm just curious as from what i can see they look like they even have different model numbers
Nema23 Stepper Motor 3.1Nm x 3 are the well recommended 439oz motors that everyone has said i need from this forum.
and yet when i look around the closest i find is these 3 PCS Nema 23 stepper motor 425oz-in,4.2A,2phase CNC Engrave www.wantmotor.com | eBay which from reading i dont really know if they are the same or not?? i suppose its really null and void as they are acctually more expensive anyway, i was just looking at that company as they are who i'm buying my drivers from
22-01-2013 #4
Wilfy, the title says 425 the listing says 428 ? :rollseyes:, it also says 30kg-cm that converts to 416oz-in and that is 2.9Nm.
It's so close i wouldn't worry too much, choose some 3Nm motors and crack on, have a good look at the specs, buying from a reputable source maybe somthing to think about. There are a number of manufacturers out there so model numbers will be different, its what is inside the motor that counts hence "reputable source".
.MeLee
22-01-2013 #5
Check what the phase inductance of the motors is. Virtually all of the cheap ones have a significantly greater inductance than the 3Nm motors from Zapp or CNC4You. If it's more than those don't bother with them since it will substantially limit the torque output as rpm increases.
The Following User Says Thank You to Jonathan For This Useful Post:
22-01-2013 #6
Yea forgot to mention "look for the best inductance" you can find....well spotted JB.
.MeLee
13-04-2013 #7
Info needed please.
I have 4 x nema23 (57BYGH56-401A) these seem to be ony 175 OZ-in.
x=1500mm, y= 750mm, z=300mm
Im on a very low budget, I can up grade later if needed.
I hope to cut plastic, mdf, 3mm Aluminium, car dash board.
Any feed back most welcome.Last edited by jamie aust; 13-04-2013 at 01:03 AM.
13-04-2013 #8
Jamie you may have answered your own question? You could gear them down to get more torque. By the time you have spent out doing that you may be better off putting them on Ebay and buying some more. If you just wanted to cut thin material then you maybe ok.
The Following User Says Thank You to Swarfing For This Useful Post:
14-04-2013 #9
If i used two of the motors i now have on the x axis, will this work ?
Next, what axis Y or Z has the least load so that I can use another one of the motors I now have, im thinking maybe the Z is that correct ?
If i can get away with both of the above, all I need to do is get a bigger motor for the Y axis.
Thanks for your time.
15-04-2013 #10
Anyone able to give me some more input, It would really help me out here, thanks.
Nema 34 motors
By Tomnewry in forum Stepper & Servo MotorsReplies: 8Last Post: 05-07-2013, 06:38 PM -
motor mount nema 23
By Swarfing in forum Motor MountsReplies: 1Last Post: 07-03-2013, 01:03 PM -
FOR SALE: Nema 23 4Nm Stepper Motor
By Shinobiwan in forum Items For SaleReplies: 16Last Post: 07-02-2013, 02:15 PM -
NEMA Standards
By Ricardoco in forum Stepper & Servo MotorsReplies: 6Last Post: 15-11-2012, 09:43 PM -
RFQ: Nema 23 motor mounts
By luke11cnc in forum Projects, Jobs & RequestsReplies: 14Last Post: 06-10-2011, 02:21 PM
