    morning all im looking to get these parts knocked up on a lathe save me buying one i need 100 in black acetal but will likely need more doing there after.
    they will need further machineing by me to fit other parts so must be bang on although the overall diameter is not critical just so long as it doesnt fall below a certain size ,i can supply the acetal bar from plastics direct unless you can do it cheaper.
    i cant go above £1.25 a prt my price is based on what ive already been quoted to do the full machining of them which was £5 per part all in.
    i,ll attatch images of the part both sides but im not sure what format to save it in as a model so i can pin it here to look at
    to give a rough idea to size the part is 9mm thick overall and diameter is 38.5mm overall ta
Name:	acetal disks 005.jpg
Name:	acetal disks 002.jpg
  1. RFQ: lathe work brass pins small
    Last Post: 20-01-2015, 03:41 PM
  2. RFQ: Acetal parts needed
    Last Post: 02-11-2013, 04:59 PM
  3. WANTED: Need a tiny bit of work done on lathe
    By Tenson in forum Items Wanted
    Last Post: 28-02-2013, 12:22 AM
  4. RFQ: Turned parts required
    By DesignR in forum Projects, Jobs & Requests
    Last Post: 23-02-2012, 12:26 AM
  5. RFQ: Precision Turned/Ground parts
    By Jimmybristol in forum Projects, Jobs & Requests
    Last Post: 08-01-2011, 04:12 PM
