Ok... I have a spare PC PSU. 12V (Model LC B200SFX)
If I use this to power the sensor, I connect the PSU -0V to the sensor and to the Gnd terminal on the BOB as shown "right ?" plus the +12V to the sensor input. Using the 1K5 to limit the input to the BOB.
Do I still need a pull up resistor ?..... Its getting a bit confusing for me.Last edited by dudz; 14-06-2013 at 05:41 PM.
Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
14-06-2013 #2
6543210987
The Following User Says Thank You to m_c For This Useful Post:
15-06-2013 #3
I feel a bit annoyed with myself. I had a diploma in Electronics servicing in 1986. I looked at my college folder from back then, And to be honest I don't understand much of it now. There was more work in Electrics rather than electronics back then, so didn't take it any further.
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Proximity Wiring Problem
By Bruce in forum General ElectronicsReplies: 7Last Post: 13-01-2014, 07:21 PM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity sensor help required
By plasticsales in forum General ElectronicsReplies: 12Last Post: 21-08-2013, 07:02 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
