Hi
Im a complete novice on CNC machines. I was originally looking into buying a laser machine but then realised to cut the thickness I was after the cost was ridiculous and I came across CNC machines. Which to be honest Ive never heard of before untill yesterday...
I want to cut wood, mainly MDF shapes and letter. Aprox 15mm depth and no larger than 30cm length.
Ive seen one on ebay which I think will be ideal and in my price range its a CNC 3020T, is within my price range £350
Does anyone know what software I would require to design them, and how easy it is? I cant imagine its too difficult to design the lettering and shapes I want to cut. ...Im a complete novice, I do apologise.
14-06-2013 #2
I cant comment on the machine but regarding software to get you going look up artcam express it would be a great start and a little over 100 notes,it will enable you to do what you want aswell as create the tool paths afterwards.
same as vectrics cut2d vectric aspire,vcarve you,ll find its a doddleLast edited by dazza; 14-06-2013 at 03:19 PM.
14-06-2013 #3
Welcome to the forum, don't know much about these machines personally but from what I have read on this & other forums it seems to be a bit hit & miss with them, you either get one that seems to be ok or is a pile of junk & not really usable unless you spend a lot of money putting it right. Biggest problem with them seems to be the control system.
There doesn't seem to be a lot of help & support from sellers of them either so if you do get one with a problem you are pretty much on your own. If you have no experience with engineering/electronics then you might just as well put the money in the bucket & if you do have some experience you might still have to spend quite a lot more to get a usable machine.
Then again you might be lucky & everything works as it should straight out the box, are you a gambler???
Software wise again it depends what you want to do & how much you are prepared to spend, free software about that works perfectly well but doesn't have a lot of support so you have to muddle through yourself trying to figure things out or commercial software from people like vectric that has lots of support & tutorials to get you started.
Does the machine come with any software to start with??
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
NEW MEMBER: Newbie to CNC
By thuncle in forum New Member IntroductionsReplies: 3Last Post: 12-09-2013, 07:13 PM -
NEW MEMBER: newbie machine owner..
By geoff f in forum New Member IntroductionsReplies: 10Last Post: 02-04-2013, 12:43 PM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
newbie need advice on cnc machine to purchase? routoutcnc machines any good?
By wyndham in forum Milling Machines, Builds & ConversionsReplies: 9Last Post: 27-05-2011, 08:54 PM
