    Don't waste your time with Acme Lead screws because you can buy ballscrews from China for the same or even less money than you'll buy lead screw in this country.
    Unless you buy very high quality Lead screw and Nuts then your wasting your money has the accuracy will be poor. Also cheap Acme screws are far less efficient than ball-screws giving less performance from the same motors. Quality Acme screw/nut will cost more than Chinese ball-scews and still probably not match them in efficiency.
    EDIT: 12mm or 16mm dia 5mm pitch will be perfect for your needs. If plan cutting woods or plastics then go for 10mm pitch.
    Contact Chai at linear-motion-bearings giving dimensions and asking for quote with end machining you require or to match the BF/BK bearing blocks if you plan on using these and think you'll be pleasantly surprised at the price.
    Chai's Email [email protected]
  1. Looking for a dremel sized cnc router
    By isdngirl in forum Marketplace Discussion
    Last Post: 29-04-2014, 12:01 AM
  2. Suggestions please on a small desktop CNC, lead screws or belt drive?
    By Tanky_Turk in forum Linear & Rotary Motion
    Last Post: 02-02-2014, 03:07 PM
  3. threaded rod/lead screws
    By deannos in forum Gantry/Router Machines & Building
    Last Post: 23-05-2011, 09:40 AM
  4. WANTED: Boxford Imperial Lead screw + Half nut
    By rnr107 in forum Items Wanted
    Last Post: 26-12-2010, 10:01 AM
  5. RFQ: Custom sized aluminium enclosure required
    By benbenrf in forum Projects, Jobs & Requests
    Last Post: 26-10-2009, 04:16 PM
