Thread: Accuracy Problem
16-06-2013 #10
Chances are it won't be a drive problem. Looking at the holes offsets and the fact they offset consistently it's More likely to be either a lose coupler slipping or you have acceleration set to high in Mach causing it to jump the odd step on direction changes.
Post the tap files and will check for you. Will combine into one G-code file and then you'll see on the screen if holes are offset or whether the machines causing the problem.
Tool diameter accuracy
By Neale in forum Tool & Tooling TechnologyReplies: 15Last Post: 05-03-2014, 11:18 PM -
Help needed with understanding accuracy in measuring tools. I want to go straight :-)
By Boyan Silyavski in forum Tool & Tooling TechnologyReplies: 25Last Post: 01-10-2013, 05:17 PM -
Machine bed accuracy
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 03-11-2010, 11:24 AM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM -
Ball Screw Accuracy V Price
By Wobblybootie in forum Lead Screws, Nuts & SupportsReplies: 5Last Post: 02-01-2010, 11:55 AM
