Hank i just did a little experiment. It appears that mine is not kosher in the continuity stakes. What it looks like it is intermittent. So checked my mill and that is, the 2.2kw on the router is also. It could be a question of the grease breaking that connection? So i fired the 300w spindle up and let it run for 10 mins to get the grease going, guess what....connection all the way.
22-06-2013 #2
Thanks for the info ...problem is unless it's 100% all the time, then there's gonna be a lot of tool breakages ...and I can't really spin the spindle prior to every session just to warm up the grease (my cnc sessions only last about 5-10 minutes as it is!)
As an aside, this 300W spindle has claimed its first victim - a 0.8mm drill -I forgot to put the grounding croc clip on the *%~+'ing spindle shaft (I never had to do this with my proxxon) ...this is now an emergency issue for me! lol
In the light of your results, it's now looking like bodge 'A' or bodge 'B' (or bodge 'C' which is have some spring steel press down on top of the shaft - which is what some Zen toolworks spindle owners have done)Last edited by HankMcSpank; 22-06-2013 at 04:53 PM.
22-06-2013 #3
The answer has to be a slip ring then with carbon contacts. Use something like this mounted on a disc over the top. A little spring to keep in place and your away. You can make the parts on the router easy enough :-)
DEWALT DRILL CARBON BRUSHES DC981 DC984 DC988 DW988 | eBay
or find something like this?
http://www.ebay.co.uk/itm/MILWAUKEE-...item4ac5d5ce05Last edited by Swarfing; 22-06-2013 at 04:58 PM.
22-06-2013 #4
Something a bit simpler to adapt
DEWALT N012060 CORDLESS DRILL CARBON BRUSHES DCD940 DCD945 DCD980 DCD985 | eBayIf the nagging gets really bad......Get a bigger shed:naughty:
22-06-2013 #5
Thanks, they're good options - many thanks for the heads up.
In the meantime, I've lashed up a bodge (like I say, bodges I can do!)...
Bodge 'A' ...aka 'spring loaded test probe pushing down on the centre of the spindle shaft'....
(there should be 4 screws holding that top piece up....but I only have 3 screws long enough to hand (it'll probably never see a fourth!)
...it works :-)Last edited by HankMcSpank; 22-06-2013 at 07:10 PM.
22-06-2013 #6
Nice one!
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
eBay: 300W 12V-48V DC High speed air cooled spindle motor for engraving milling
By Swarfing in forum Items On eBay UKReplies: 0Last Post: 16-06-2013, 01:33 PM -
dc motor - spindle / shaft drive
By dsc in forum Spindles & Drive MotorsReplies: 21Last Post: 01-06-2013, 10:42 AM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
