Thread: Adjustable spindle mount?
18-06-2013 #1
Does anyone know if some sort of adjustable spindle mount is available anywhere? My machines spindle is slightly off axis which leaves lines on the work (tramming?). Would be great if there was something adjustable so I could easily dial out any errors as at the moment I just have 4 bolts holding the spindle which is no so easy to adjust...
Thanks,
Jim
18-06-2013 #2
Try modern technology - Make the bolt holes bigger ,the fit a couple of dowels. (I'll get moaned at for that!!). G.
19-06-2013 #3
Not quite the modern tech answer I was looking for!
Moaning has been the reason I haven't mentioned my machine is based on UNsupported rails!
I have seen some of the great builds on here and mine needs a lot of work (maybe less work to start again...) to get to those levels!
Jim
spindle mount
By martin54 in forum Marketplace DiscussionReplies: 14Last Post: 19-01-2016, 09:09 AM -
RFQ: Spindle Mount (Ali mill job) - one off
By Doddy in forum Projects, Jobs & RequestsReplies: 3Last Post: 05-02-2014, 06:42 PM -
RFQ: Spindle mount
By jcb121 in forum Projects, Jobs & RequestsReplies: 4Last Post: 05-02-2012, 02:49 PM -
RFQ: RFQ - custom 43mm spindle mount
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 15Last Post: 03-11-2011, 09:52 PM -
Secondary Kress spindle mount.. Does it exist?
By fasteddy in forum Kress Milling MotorsReplies: 6Last Post: 18-08-2010, 05:25 PM
