31-12-2015 #13
Hi Chaz,
No idea what the maximum is... I never reached it.... But I did turn 2" bars without any problem.
In brass I'd say as long the stock clears the bed and the carriage you should be fine (using the internal jaws).
What kind of diameter are you thinking of ?
The spindle bore is 20mm this limit the diameter if you have a long bar that need to go throu the spindle.
But apart from that, the Orac is a very capable lathe. I mostly use it on stainless and a bit of ali. Brass would be a piece of cake.
RNR
Kress Spindle upgrade to a 2kw
By Metal pecker in forum Kress Milling MotorsReplies: 4Last Post: 05-05-2014, 12:22 PM -
denford orac tail stock dimensions
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 3Last Post: 24-11-2013, 10:42 PM -
RFQ: Spindle for a Denford ORAC
By rnr107 in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2012, 05:20 PM -
Orac lathe
By phill05 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-07-2012, 09:05 PM -
Mini Lathe - chuck key, long nose type sourceable?
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 19-10-2009, 01:41 PM
