Thread: First project! A Maya Calendar
I see - Thanks for that.
Another question if I may - I noticed that after the circle profile cut it was uneven in a couple of places. It seems to be on the Y axis and from what I have read I think it may be backlash in that axis, does that sound right? one side of the circle it was very obvious, a slight jut out from the circle, the opposite side not so much - I wish I measured it now but I gave it to my Dad for fathers day!
24-06-2013 #2
Backlash can cause the effect you describe. It could be something else, like a slightly loose pulley/coupling, but that seems less likely since the rest of the part isn't all over the place. If you're machine is driven by ballscrews then you're unlikely to notice their backlash on wood, since it's very small (<0.05mm). That's not the case if you've used ACME or threaded rod...
24-06-2013 #3
Heiz CNC Project
By sola in forum Heiz CNC RoutersReplies: 5Last Post: 30-04-2017, 12:11 AM -
NEW MEMBER: Hello, time for a project
By Topping tools in forum New Member IntroductionsReplies: 1Last Post: 11-06-2014, 10:18 AM -
RFQ: I need Help/Support with my project :)
By gianluca_g in forum Projects, Jobs & RequestsReplies: 16Last Post: 06-05-2012, 10:00 PM -
Homemade CNC Project Help
By chaslam07 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 04-04-2012, 11:53 AM -
RFQ: Small CNC Project
By flipflop in forum Projects, Jobs & RequestsReplies: 1Last Post: 20-09-2011, 10:41 PM
