Thread: Hand Ergometer
25-06-2013 #11
Just found this to get some ideas Plastic Gears ...Clive
26-06-2013 #12
That looks ok for printing - probably best if I get the finer extruder going but I've made some gears about that size which work ok. Could the unit be thicker? I'm thinking that it's maybe a bit marginal on strength - probably easiest to just build it and test it than worry too much at this point though.
If you (or anyone else) can point me towards a gear profile calculator (can't find one that does the outer ring) I'll knock up something for a strength test.
27-06-2013 #13
27-06-2013 #14
Irving Can't seem to open that link. ....Clive
27-06-2013 #15
Strength calcs: Calculate for input gear as worst case (Ref: Spur Gears)
Input torque = power/revs = 90/6 = 15Nm, add 50% for safety = 22.5Nm
Tangential force on tooth Ft = 2 * torque/PCD = 2 * 22.5/.01875 = 2400N
Bending stress = K * Ft/(b * m * Y)
K=velocity factor, estimated at 1.03
b = face width = 6mm
m = module = 1.25
Y = Lewis Form Factor = from tables, for 15T 20deg gear = .289 @ tip .49 @ centre of tooth, use .289
stress = 1.03 * 2400/( 6 * 1.25 * .289) = 1140MPa = ~165kPSI
PLA = 500kPSI so should be OK!Last edited by irving2008; 27-06-2013 at 12:32 PM.
27-06-2013 #16
27-06-2013 #17
27-06-2013 #18
27-06-2013 #19
I'd go for a timing belt drive for three reasons:
- It's not unlikely that we might find the ratio needs changing and to change the ratio you only need to change one pulley compared to two gears.
- The torque ripple will also be less with a belt, unless maybe someone wants to have a go at making helical gears!
- Noise.
27-06-2013 #20
1. I suppose its possible it might need changing, but a 3:1 ratio means 180rpm on the rotor and thats more than enough, can even use smaller/fewer magnets as torque requirement reduced by same ratio.
2. Not sure what you mean by torque ripple in this context, its an artifact of a motor due to bad pole design aka cogging...
3. Maybe, but plastic gears shouldn't be that noisy at these low speeds...
Epicyclic is elegant solution to problem. Belt drive would need to find a way to route belt past magnetic pole piece each end of magnet carrier, or carrier would need to be vertical or at least at an angle making use of the U-channel mounting more difficult and making the mounting of the loadcell more complex. Also belt drive might increase the footprint.
Second hand machines & their features
By navins in forum Machine DiscussionReplies: 5Last Post: 19-03-2014, 11:01 AM -
RFQ: Parts for hand ergometer (exercise bike)
By irving2008 in forum Projects, Jobs & RequestsReplies: 29Last Post: 16-09-2013, 12:46 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
