Thread: Hand Ergometer
01-08-2013 #29
Not been a great week what with heat and other issues but trying to get back on track.
Been prevaricating over how to retain bearings in the planet gears The revised gears are 10mm thick and the bearings I'm going with are 3 x 9 x 4. The planet carrier has a 3mm boss and with a 3mm caphead screw as an axle the bearing will be centrally located in the gear against a recess. but that doesn't stop the gear sliding off the bearing. Normally you'd have some sort of bearing retainer but the only way I can see to do this with a 3D printed gear is either a groove 'not printed' to take a circlip which means an overhang (do-able but not ideal) or some sort of printed protrusion which will deform enough to allow the bearing to be pressed into place (is this possible?).
Thoughts?
Second hand machines & their features
By navins in forum Machine DiscussionReplies: 5Last Post: 19-03-2014, 11:01 AM -
RFQ: Parts for hand ergometer (exercise bike)
By irving2008 in forum Projects, Jobs & RequestsReplies: 29Last Post: 16-09-2013, 12:46 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
