    On mine the outside of the bearing is fixed, the inside floats. no real right or wrong way. It just stops the screw from whipping about.
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Indeed if it's only used to stop the whipping, if it's supposed to carry any load, then it depends where the load is attached and that affects how the inside / outside rings should be fixed (and what fit should be used).
    Regards,
    dsc.
    The load is on the other end, the screw is turned down at the floating end with a gap between the thread of the screw and bearing. The commercial ones off ebay and the likes have a circlip holding the bearing onto the screw. In this situation the bearing should be a loose fit into it's mounting.
  1. advice on floating bearing - outer ting rotating
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 18-11-2013, 02:23 PM
  2. Mach3 and CNC3040 incorrect zero location
    By RoyT in forum Artsoft Mach (3 & 4)
    Last Post: 30-10-2013, 03:29 AM
  3. Pulley grub screw location
    By booski in forum Belt Drive, Pulleys & Timing
    Last Post: 30-07-2013, 12:56 PM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  5. Location of machine problem
    By Eugene in forum Computer Software
    Last Post: 27-01-2011, 07:00 AM
