25-06-2013 #1
I am using the Big-tex version on Mach3. I have installed the auto zero script.
I am using a tool offset block sensor.. CNC Werkzeuglängensensor Werkzeuglängentaster Werkzeugtaster Taster Werkzeug-Taster Werkzeugsensor Sensor Werkzeugvermessung -CNC-Plus Germany
The hight offset of the block is in the "guage block hight" in "offsets"
When I press the button "Initial Zero setup" when x and y are homed, the Z moves down as it should and reaches the block....moves up...returns and touches the block once more and rises around 150mm. That is where I thought the process should stop, but then the Y axis moves near the center of the table and repeats the whole process again before Mach shows me the Z is set. I do not have a fixed Z plate as my X axis bed moves. How do I instruct the script to only preform the operation once, wherever X, or Y axis happen to be ?
Sub Main() 'made it a sub, so you can return on "show stopper" errors
'Option Explicit 'Written by Big-Tex Dec 26 2010
'Mod pb 11dec10
Dim ZNew, Zplate, Zrestposition, ZMaterialmachcoord, ZPlatejobcoord, Zplatetomaterial
Dim xjobcoord, yjobcoord, xmachcoord, ymachcoord, zmachcoord
Dim xprobeloc, yprobeloc, xtoprobe, ytoprobe, PlateOffset
Dim CurrentFeed
Dim CurrentAbsInc
xjobcoord = GetDRO(0) 'get current job coordinate for X
yjobcoord = GetDRO(1) 'get current job coordinate for Y
xmachcoord = GetOemDRO(83) 'get current machine coordinate for X
ymachcoord = GetOemDRO(84) 'get current machine coordinate for Y
zmachcoord = GetOemDRO(85) 'get current machine coordinate for Z
xprobeloc = GetUserDRO(1100) 'get X machine coordinate location of the touch plate
yprobeloc = GetUserDRO(1101) 'get Y machine coordinate location of the touch plate
xtoprobe = (xprobeloc - xmachcoord + xjobcoord) 'calculate the X move from the current location to the touch plate
ytoprobe = (yprobeloc - ymachcoord + yjobcoord) 'calculate the Y move from the current location to the touch plate
PlateOffset = GetUserDRO(1151) 'get plate offset DRO
CurrentFeed = GetOemDRO(818) 'get the current feedrate to return to later
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
'//////// the block below will set all your reusable vars depending on Inch or mm.
'//////// this sets the vars so you only need ONE large block of probing code.
If GetOEMLED(801) Then 'ON = English Measure INCH
FirstProbeDist = 6.0 'first probe travel
FirstRetractDist = 0.1 'first probe retract travel
SecProbeDist = 0.25 'second probe travel
FirstProbeFeed = 10 'First Probe Feed Speed
SecondProbeFeed = 2 'Second Probe Feed Speed
'CalcRetract = 2.6315 'calc retract
Zretract = -0.5 'Z reftact
Else 'OFF = Metric Measure MM
FirstProbeDist = 150.0 'first probe travel
FirstRetractDist = 3.0 'first probe retract travel
SecProbeDist = 6.0 'second probe travel
FirstProbeFeed = 300 'First Probe Feed Speed
SecondProbeFeed = 50 'Second Probe Feed Speed
'CalcRetract = 50 'calc retract
Zretract = -12 'Z retract
End IfSwedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
3 axis CNC/router / Alu profile frame....25mm Alu Cutting bed X=500mm Y=300mm Z=110mm.....Supported 25mm X rails ....Supported 20mm Y rails....Supported 20mm Z rails.....2.2kw Chinese WC spindle..... CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller....M542 Drivers..SY60STH86-3008BF Motors...running....Mach3 / Cambam / Emachineshop.
Help Please With Auto Tool Height Mach 3 Problem
By howser37 in forum Probing, Digitizing & ScaningReplies: 26Last Post: 12-06-2014, 07:55 PM -
Help with Mach3 inputs and VB script ?
By EddyCurrent in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 27-11-2013, 06:35 PM -
Tool Pre-setter
By Leadhead in forum Tool & Tooling TechnologyReplies: 6Last Post: 28-09-2013, 10:56 AM -
Help with mach3 center finding script
By eddie60 in forum Programmers CornerReplies: 7Last Post: 20-05-2009, 06:23 PM -
BUILD LOG: Version 0.1
By SirMorris in forum DIY Router Build LogsReplies: 7Last Post: 11-08-2007, 02:52 PM
