I guess it all depends on the quantity of tins you want to put holes in. If you're doing a few, then a nicely constructed drilling jig would allow you to quickly clamp and drill all your holes within a minute or two.
28-06-2013 #2
milehighclub
28-06-2013 #3
I am aiming to do quite alot , the drill I have tried it tends to tear the metal and because its PCB mounted equipment I want it quite precise so it looks good.. i have looked at a numatic set of rams , but i want something simple to start with.
Ralph Waldo Emerson
28-06-2013 #4
Have a look on the web for a Whitney hand punch, I have an old one that goes to 1/4", does 16swg steel ok but you should centre punch first to get a good location.
Just had a look on the web and they appear to be quite expensive! But they do work!!
peter
28-06-2013 #5
To drill holes in thin sheet steel as others have said sandwich between to pieces of wood but main thing is do not use a normal jobbers drill but grind one up like a wood bit as a wing and spur.
If you have decent wood bits you could just use one of these but most i have come across aren't even hardened hence the grinding up of the wing and spur.
Worth keeping a few as they are also ideal on plastics and prevent splitting as they exit the hole.
John S.Last edited by John S; 28-06-2013 at 09:36 AM.
John S -
The Following User Says Thank You to John S For This Useful Post:
28-06-2013 #6
therefore maybe something like these at the right speed...
Dremel Brad Point Drill Bit Set - 631 | eBay (they go up to 1/4")
never used them for tin, but they work great on acrylic! (& handy to have in your arsenal of bits - especially if your machine is confined/restricted to a 1/8" collet, such as a rotary tool in this arrangment - https://www.google.co.uk/shopping/pr...g&ved=0CCAQrRI)Last edited by HankMcSpank; 28-06-2013 at 10:16 AM.
28-06-2013 #7
I want to avoid drilling if I can , I want a sort of high bred clamp come punch template combo , ill work on it and see what I can do, thanks for the replies guys :)
Ralph Waldo Emerson
The new probe and finding the center of a hole
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 13-11-2015, 06:43 AM -
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM
