All great ideas but I have to be quite accurate with the holes, after marking them out then drilling chances are they won’t be that accurate. The PCB has about 5 mounted parts that need to go through the holes on different sides and there’s no play. Plus they have to be neat. So that’s why Im thinking of making a template I can slip over the edge of the tin box, sort of an inverted U shape and then using a hardened bolt that’s been cut down with a cutting edge done on a lathe that then screws through the die and punches out the holes.
Ralph Waldo Emerson
01-07-2013 #2
A bit like these:-
Q.max Sheet Metal Hole Punch 25mm
But I don't think they are made down to 5mm. ...Clive
01-07-2013 #3
Or perhaps this ? Buy Punch & Die Kits Hand punch kit with die key RS DA1230 online from RS for next day delivery. ....Rob
The Following User Says Thank You to cropwell For This Useful Post:
01-07-2013 #4
Ralph Waldo Emerson
01-07-2013 #5
Easy enough to make your own punches and dies using something like EN8. Heat to cherry red and quench in oil to harden. It's about time you built a CNC punching machine.
The new probe and finding the center of a hole
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 13-11-2015, 06:43 AM -
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM
