28-06-2013 #10
To drill holes in thin sheet steel as others have said sandwich between to pieces of wood but main thing is do not use a normal jobbers drill but grind one up like a wood bit as a wing and spur.
If you have decent wood bits you could just use one of these but most i have come across aren't even hardened hence the grinding up of the wing and spur.
Worth keeping a few as they are also ideal on plastics and prevent splitting as they exit the hole.
John S.Last edited by John S; 28-06-2013 at 09:36 AM.
John S -
The Following User Says Thank You to John S For This Useful Post:
The new probe and finding the center of a hole
By Ricardoco in forum Probing, Digitizing & ScaningReplies: 9Last Post: 13-11-2015, 06:43 AM -
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM
