Thread: AC servo motor help !
30-12-2013 #31
The bigger question is WHY? What benefit will you get adding rs232/485 capability? Seems a lot of work for little return plus the internal software of the VFD may not be configured to use it.
30-12-2013 #32
No its not big work because i have PS/2 connector & spare smd parts
i have ordered 10pcs from each ICs (max232 & SP485) from ebay and i have allready found the most parts values.
The manufacturer price for this operation is only 50 cny ( 6 euros )
´®¿Ú¹¦Äܲ¹²î¼Û-ÌÔ±¦Íø so i will try to pay him to give me the values of components.
The driver supports rs232/485 with extra 6 euro.
I found manufacturer(perhaps wholesale seller) webpage: cnyfdz.com
Also i have tested the driver with the connection phase -> L1-L2 bridged , neutral -> L3 and works fine with using 2 rectifiers (8 of 8 diodes in the 2 rectifiers).
So this is the proper way to connect this drive in single phase 230VAC next is to measure DC bus for ripple on big electrolytic caps (with default 3 caps)
I want to connect these servos with pc (mach3) and because for first time iam using servos i need some help how to connect them with pc parallel port.
Here is the manual of this drive version 3 (in version 2 a lot of things are wrong/missing)Last edited by vre; 02-01-2014 at 06:52 AM.
22-07-2014 #33
I found all missing electronic components for rs232 rs485 connection (i have tested the connection with these components and works fine)
R78 470R
R79 470R
R134 4k7
R137 4k7
R80 5k1
R135 5k1
R139 5k1
R132 10R
R136 10R
C65 1uF
C66 1uF
C70 1uF
C67 1uF
C68 1uF
C69 0.1uF
C106 0.1uF
D11 S4 signal diode
D12 S4 signal diode
Z1 SMB 6.8CA TVS
Z2 SMB 6.8CA TVS
U22 MAX232 16pins (with MAX232A C65 C66 C70 C67 C68 = 0.1uF)
U35 MAX485 8pins
CN1 PS/2 connector 6pins (The holder for the fuse in L1 line must removed and the fuse must soldered without the fuse holder because there is not enough free space for PS/2 6pins connector)
Also the new version of manual ASDD-30A ( v3.1 )
http://www.filedropper.com/asdd-30aenv31
http://www5.zippyshare.com/v/38122167/file.html
http://www.filedropper.com/asdd-30acnv31
http://www5.zippyshare.com/v/13393384/file.htmlLast edited by vre; 22-07-2014 at 01:57 AM.
22-07-2014 #34
I am baffled by your mod. Very brave.
22-07-2014 #35
Also 2 free programs to set parameters with modbus i have tested and worked fine are qModMaster and qModBus
10-08-2015 #36
new manual ASDD-30A v3.4
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
What size servo motor do I need.
By Jonathan in forum Stepper & Servo MotorsReplies: 1Last Post: 31-03-2014, 09:16 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
Servo motor sizing?
By gavztheouch in forum Stepper & Servo MotorsReplies: 1Last Post: 18-04-2013, 11:40 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
