  1. The bigger question is WHY? What benefit will you get adding rs232/485 capability? Seems a lot of work for little return plus the internal software of the VFD may not be configured to use it.
  2. #32
    vre's Avatar
    Lives in Athens, Greece. Last Activity: 19-05-2022 Has been a member for 9-10 years. Has a total post count of 39.
    No its not big work because i have PS/2 connector & spare smd parts
    i have ordered 10pcs from each ICs (max232 & SP485) from ebay and i have allready found the most parts values.
    The manufacturer price for this operation is only 50 cny ( 6 euros )
    ´®¿Ú¹¦Äܲ¹²î¼Û-ÌÔ±¦Íø so i will try to pay him to give me the values of components.
    The driver supports rs232/485 with extra 6 euro.
    I found manufacturer(perhaps wholesale seller) webpage: cnyfdz.com
    Also i have tested the driver with the connection phase -> L1-L2 bridged , neutral -> L3 and works fine with using 2 rectifiers (8 of 8 diodes in the 2 rectifiers).
    So this is the proper way to connect this drive in single phase 230VAC next is to measure DC bus for ripple on big electrolytic caps (with default 3 caps)
    I want to connect these servos with pc (mach3) and because for first time iam using servos i need some help how to connect them with pc parallel port.
    Here is the manual of this drive version 3 (in version 2 a lot of things are wrong/missing)
    Attached Thumbnails Attached Thumbnails Servo drives 使用手册.pdf
  3. #33
    vre's Avatar
    I found all missing electronic components for rs232 rs485 connection (i have tested the connection with these components and works fine)
    R78 470R
    R79 470R
    R134 4k7
    R137 4k7
    R80 5k1
    R135 5k1
    R139 5k1
    R132 10R
    R136 10R
    C65 1uF
    C66 1uF
    C70 1uF
    C67 1uF
    C68 1uF
    C69 0.1uF
    C106 0.1uF
    D11 S4 signal diode
    D12 S4 signal diode
    Z1 SMB 6.8CA TVS
    Z2 SMB 6.8CA TVS
    U22 MAX232 16pins (with MAX232A C65 C66 C70 C67 C68 = 0.1uF)
    U35 MAX485 8pins
    CN1 PS/2 connector 6pins (The holder for the fuse in L1 line must removed and the fuse must soldered without the fuse holder because there is not enough free space for PS/2 6pins connector)
    Also the new version of manual ASDD-30A ( v3.1 )
    http://www.filedropper.com/asdd-30aenv31
    http://www5.zippyshare.com/v/38122167/file.html
    http://www.filedropper.com/asdd-30acnv31
    http://www5.zippyshare.com/v/13393384/file.html
  4. #34
    I am baffled by your mod. Very brave.
  5. #35
    vre's Avatar
    Also 2 free programs to set parameters with modbus i have tested and worked fine are qModMaster and qModBus
  6. #36
    vre's Avatar
    new manual ASDD-30A v3.4
    Attached Thumbnails Attached Thumbnails 克瑞斯伺服v3.4(驱动器说明书).pdf
  1. Replies: 2
  2. What size servo motor do I need.
    By Jonathan in forum Stepper & Servo Motors
    Last Post: 31-03-2014, 09:16 PM
  3. 2.2kw servo motor for spindle
    By blayde in forum Spindles & Drive Motors
    Last Post: 01-01-2014, 04:48 AM
  4. Servo motor sizing?
    By gavztheouch in forum Stepper & Servo Motors
    Last Post: 18-04-2013, 11:40 PM
  5. servo motor as spindle motor
    By Scott in forum General Discussion
    Last Post: 03-10-2010, 06:42 PM
