Thread: AC servo motor help !
28-12-2013 #10
Some more questions..
How to connect the single phase to L1/L2/L3 of driver ? phase -> L1 , neutral -> L2 , phase -> L3 OR neutral -> L1 , phase -> L2 , phase -> L3 OR it doesn't matter ?
If 1 or 2 of rectifiers fails what other failure can be happen in the drive ?
Must change the rectifiers with bigger current rectifiers ? how much bigger ?
(I have an oscilloscope so i can see if voltage is smooth when i add extra caps)
My driver specs (from here http://item.taobao.com/item.htm?id=1...catid=50006522 ):
AASD 30A servo motor parameters
Rated current :0 - 10A
Rated Power :0 - 3KW
Rated line voltage: 220V
Peak Current: 30A
Rated speed :0 - 3000Last edited by vre; 28-12-2013 at 04:04 PM.
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
What size servo motor do I need.
By Jonathan in forum Stepper & Servo MotorsReplies: 1Last Post: 31-03-2014, 09:16 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
Servo motor sizing?
By gavztheouch in forum Stepper & Servo MotorsReplies: 1Last Post: 18-04-2013, 11:40 PM -
servo motor as spindle motor
By Scott in forum General DiscussionReplies: 1Last Post: 03-10-2010, 06:42 PM
