Thread: G codes
You are right, another way to look at it is... Your spindle will arrive at X5 Y10 at the same time, so it will need to travel faster in Y than X.
23-09-2013 #2
Depends on the Parameter set up of the machine
IF the Parameter is turned on for straight line rapid that's what it will do
IF you want to go to the point Straight line -G01 X5.0 Y10.0 F500.0 and will always arrive at the point together
Goo X5.0 and Y10.0 depends on the above parameter setting
Difference between Mazatrol and G-codes
By hoezap in forum Mazak, Yamazaki MachinesReplies: 5Last Post: 23-04-2023, 04:59 PM -
Stepper Motor Wire Colour Codes
By c cunningham in forum Stepper & Servo MotorsReplies: 14Last Post: 26-01-2011, 02:13 PM
