    hello,welcome to the site.
    i was in the same boat for a time,i liked the idea of building a vertical mill but settled on knocking up a fixed gantry mill,see image ,im fairly happy with it, its sole jobs for plastics and aluminium and it does what i want.
    if i were fixed on a vertical mill now id be inclined to just convert one to cnc
    Quote Originally Posted by deisel View Post
    I like that design :-) - you say you are "fairly happy" with it - what problems do you have and what changes would you make if you were doing it again?
    Quote Originally Posted by FatFreddie View Post
    i shouldnt have said fairly i am happy with it, but there are things id do slightly different,things like having slots ground into the face of the y axis for the rail for easier alignment same with the bed id probably have put a slab of tooling plate down with slots ground in for the x rail.
    and i really wish id made provisions for collecting all the coolant fluid and chips rather than worry about it after the build,
  4. The Following User Says Thank You to dazza For This Useful Post:
  5. #4
    I have seen this machine in the flesh, and it really is rigid, robust and looks very workmanlike. Very impressed, well done. G.
  6. #5
    Thank you deisel. I considered a vertical mill configuration because of space constraints and the material I already have available to me. I really like the simplicity of your setup and may adopt a similar setup after reading your build thread (if there is one) and seeing what I would need. Thanks for sharing and I look forward to hearing alot more feedback and advice from you and others in this forum. :-)
  1. NEW MEMBER: Sooo much to learn...
    By techcobweb in forum New Member Introductions
    Last Post: 19-03-2013, 02:59 PM
  2. NEW MEMBER: New Member desperate to learn
    By Mill Grav Newbie in forum New Member Introductions
    Last Post: 24-04-2012, 01:17 PM
  3. NEW MEMBER: Here to learn
    By Mjolinor in forum New Member Introductions
    Last Post: 06-09-2011, 07:56 PM
  4. NEW MEMBER: Here to learn
    By Pol in forum New Member Introductions
    Last Post: 11-08-2011, 02:50 PM
  5. Where did you learn electronics?
    By AlexBanich in forum General Electronics
    Last Post: 29-07-2009, 03:22 PM
