Thread: Bertha
Either will work. just make sure you can triangulate the largest area you can. You really can't over do it but very easily can under do it.!!
Yes this will work fine. The Axial alignment needs to close but not super critical, the FK at each end will make it a bit trickier but you'll be fine. Regards if it's better or not then Yes but how much at this level is debatable and one I'm not getting into so don't anybody ask me too.!!
You won't fasten those blocks to the Extrusion slots of 60x30 if that's what you plan on doing.?
I may be miss understanding here.??. . . . Regards the rails and over size holes for aligning ball screws then that's a bit of hard way to go about it and will be pain. . . . . Over size holes and shims on the ball-screw mounts would be easier.
The most common cause of bent ball-screws is not from ball-screw end alignment but the distance from Ball-nut mount to screw centre. If it's out then when it approaches the bearing blocks it bends the screws. It's a slow job setting screw alignment and ball-nut mounting but worth the effort so building in has much adjustment potential greatly helps.
Well strictly speaking yes it's not the ideal but that depends on how far back and how it's done. The amount where talking here doesn't make a jot of difference and believe me if you built the machine your way and in the night I switched it without you noticing you wouldn't tell any difference, either in how it performed or quality of finish. Get silly about and then yes it show in cut quality and that's depending on what your cutting.Last edited by JAZZCNC; 11-08-2013 at 10:19 PM.
