    Increase your present 'steps per unit' (motor) setting by 25% ....then a present 80mm cut will become 100mm.
    Goto the motor settings of your CNC app & for example, if the steps per unit are presently 500, change it to 625 etc (625, equates to 500 + 25%)
    (btw your motor setting almost certainly won't be presently set for 500 .... it was just an example!)
    Thanks Hank
    I was looking for this solution since 2 days, mine was 320 steps per unit, I change it to 400
    it is perfect and accurate now.
    thanks again :)
  1. What has gone wrong????
    Last Post: 05-09-2014, 12:25 AM
  2. Ok, so whats wrong?
    By Davek0974 in forum 3D Printing Machines
    Last Post: 27-03-2014, 12:19 PM
  3. When Home 3D Printing goes wrong lol :)
    By Fivetide in forum Machine Discussion
    Last Post: 18-08-2013, 04:03 PM
  4. 1605/1610 have they sent the wrong ones?
    By kingcreaky in forum Lead Screws, Nuts & Supports
    Last Post: 30-07-2013, 09:22 PM
  5. Stepper shaft size and pulley bore size problem
