Thread: Cnc cutting the wrong size..
05-07-2013 #5
Well, the correct method is to tell us your leadscrew pitch & whether you are microstepping or not, we can then tell you what entry you should make for the 'steps per unit' setting in your CNC app, but in the absence of that info, if your 'steps per unit' setting is set to 200 at the moment & you are saying that a 100mm piece comes out at just 80mm then increase the steps per unit setting to 250 & that should see a 100mm piece come out at 100mm
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM -
Ok, so whats wrong?
By Davek0974 in forum 3D Printing MachinesReplies: 32Last Post: 27-03-2014, 12:19 PM -
When Home 3D Printing goes wrong lol :)
By Fivetide in forum Machine DiscussionReplies: 0Last Post: 18-08-2013, 04:03 PM -
1605/1610 have they sent the wrong ones?
By kingcreaky in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 30-07-2013, 09:22 PM -
Stepper shaft size and pulley bore size problem
By psiron in forum Linear & Rotary MotionReplies: 13Last Post: 15-06-2010, 04:11 PM
