    Wal's Avatar
    Hello all.
    Right, after the reasonably successful mill build, I've decided that I need a CNC lathe. Nothing too big or clever - heh, in all honesty I'm struggling to think what I'd make with it, but no doubt it'll come in handy at some point.
    The control electrics are pretty much sorted as I'll use my mill box to drive the steppers, so essentially I'm after building a couple of short linear stages (1605 ball-screws, 20mm profile rails), populating one of 'em with a tool-post and getting hold of a spindle/chuck - probably from a lathe manufacturers spares section (think Warco etc.) I've not even thought about thread cutting as yet, although it would be a very cool thing to be able to do...
    Materials to turn: 6082 mostly, brass, steel perhaps. Small scale stuff.
    I did start out thinking about a conversion until I saw this video the other day:
    https://www.youtube.com/watch?v=Y1IDHIcyHLY
    Excellent. Apart from the mind-blowingly ace turret, these are the lines along which I'm thinking.
    Do-able? Any advice/links to other builds of interest?
    All the best.
    Wal.
    Nice looking machine and pretty simple design, apart from the turret you mention, although you would definitely have to include that. I did notice there is no tailstock, are you planning on fitting one ?
    Would it be worth considering at this stage to allow adaption to a 4th axis cnc with router ?
    Wal's Avatar
    It's pretty cool, eh?
    There are plans out there for that turret, although my efforts will be more along these lines:
    https://www.youtube.com/watch?v=hnSqy0oKyTQ
    Yes, I wondered about the tailstock. Bearing in mind this will be for small scale stuff, is it essential?
    Wal.
    Wal.
    their dead handy for stopping skinny work pieces bending during cuts. Depends how much they stick out of the chuck i guess and also being cnc you can always do the boring thing of taking it down in short steps
    Stuart
    Hi Wal
    This might be worth a read.
    http://makezine.com/projects/the-mul...lathemilldrill
    regards
    Mike
    Hi Wal
    regards
    Mike
    It's like that old saying about a lathe being the only tool that can make itself.
    Or why buy it for $5 when i can make it for $50 ;)
    Stuart
    Hi Wal
    regards
    Mike
    Ah, the "Yeomans Technique", but with concrete!
    Obviously it's a technique of "Not Quite Using The Quoted Technique"
    You can't even weigh that in, at least Gingery's designs had that small advantage ;-)
    - Nick
    Frankly I would start with one of the small Sieg lathes, also sold under other names, rather than try to make your own if you don't already have a lathe. But not too small. You get a reasonably accurate bed, spindle and slides as well as the motor drive. Backlash is not nearly so critical in a lathe so you can live with the normal feed screws though ballscrews are nice to have. It is easy to underestimate the rigidity you need for a lathe as well as the fit of the slides if you want to turn anything metal. Lathes are the essential machine tool.
  9. Quote Originally Posted by JohnHaine View Post
    Agree, as long as the part is small enough a sliding table mounted vertically on the cross-slide allows you to mill things. It's what I did before I got a mill. For simple stuff you don't even need a table, a right-angle mount will do, tedious to move workpiece manually but doable
    Hi Guys
    The intention of my post was just to highlight the use of concrete as a solid base for construction not to construct the lathe shown. a couple of lengths of 25mm square steel bar and a small quantity of rebar and a simple box mould would give you a solid base on which to mount a couple of Hiwin Rails.
    I have seen on superb gantry mill manufactured this way(sorry can't find the link) but this is something similar.
    https://www.youtube.com/watch?v=fDiEi2bOXgs
    Regards
    Mike
  1. BUILD LOG: a Steel Box Section Build with SBR20 & Ballscrews Plus a few questions
    By grain_r in forum DIY Router Build Logs
    Last Post: 27-01-2023, 06:47 PM
  2. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
  3. Replies: 2
    Last Post: 22-10-2011, 12:38 PM
  4. My lathe, and possible new build
    By jpcnc in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 23-04-2011, 08:20 AM
  5. RFQ: Manual Lathe Repair & Syil SX3 CNC Re-build Required.
    By Chas in forum Projects, Jobs & Requests
    Last Post: 07-11-2010, 09:28 AM
