@Wal, glad you got it sorted and thanks same to you.
@Jazz, thanks, very glad now I ventured an opinion. My floating bearings seems to have a almost like a bit of taper and it looks like the bearing can only be pressed out to one side which is why I made the assumption. Like they say: Assumption is the mother of all f%-ups. Did not figure out that it may wear over time and the bearing might float right thru the housing. I can see that will be a very bad thing so I'm going to fit the circlips! Like I said mine appears to have a bit of taper so does it matter if the bearing is pushed to the side where its sitting a bit loose in the housing? Also, on two of my floating bearing housings, the bearings sits very tight, to the point where the have to tapped out, should I make those holes a smidgion larger so that the bearing can actually "float" in the housing instead of the shaft floating inside the bearing?Last edited by mitchejc; 02-01-2015 at 08:48 AM. Reason: need more infi
Some general questions. Drilling and pocketing.
By Wal in forum Metalwork DiscussionReplies: 1Last Post: 15-02-2014, 12:05 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Ball screw mounting questions
By Redccm in forum Lead Screws, Nuts & SupportsReplies: 3Last Post: 28-01-2011, 09:29 PM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
