    Hi All
    I was going to wait until Ive finished; but as its properly DEAD at work today, and ive exhaused ebay, and all of the forums I usually frequent under these circumstances, I thought id upload the pictures of my present build just in case anybody else is as bored as I.
    I am building the machine for a friend, who will use the machine for cutting sheet ply. I started this end of last month and I aim to have it ready for start of January
    The requirements for this build are as follows
    * It is required to cut 8x4 sheet ply, 18mm thick with a 6mm cutter
    * It needs to be wall mounted (work will be screwed to the sacrificial base)
    * The room is 3m x 3m in which it will be used. So needs to be assembled on site.
    * Its a start-up company therefore finances are tight, it must be as cheap as possible.
    The design is very similar to my other builds (same ali gantry design IL, thick 6mm steel frame) except this time Ive bolted the entire frame to allow for adjustment
    Ive cut all the steel using his three phase suds cooled industrial chop saw; which enabled me to cut the steel extremely accurately. I achieved squareness by doing minimal welding, and lots of "bolt" fixing; measuring from corner to corner.
    2510 fixed ballscrews with spinning nuts (thans jonathon)
    cheap chineese 860 drivers
    heres the lazy design anyway (no ballscrews, or triangulation on frame)
    and here is where I am so far.
  2. The Following User Says Thank You to kingcreaky For This Useful Post:
  1. laser scanner cnc router mounted
    By dazza in forum Probing, Digitizing & Scaning
    Last Post: 30-08-2014, 01:02 PM
  2. Z mounted 4th axis
    By charlieuk in forum Linear & Rotary Motion
    Last Post: 30-04-2014, 04:31 PM
  3. wall cnc like the wall saw
    By crossleymarko in forum Machine Discussion
    Last Post: 25-03-2012, 11:24 AM
  4. wall and floor fixing am I the only one ????????????
    By luke11cnc in forum General Discussion
    Last Post: 30-12-2011, 11:45 PM
  5. CNC Wall art from JPG
    By BJ- in forum Opportunities Available & Sought
    Last Post: 29-01-2010, 03:06 PM
